Tannoy fx5.1
Discussion in 'Home Cinema Speakers' started by simonph, May 18, 2004.
  1. simonph
    simonph
    May 21, 2002
    94
    Anybody got any opinions on this speaker package? Or if anyone could recommend a speaker package around the £200 mark I'd be most grateful :)
  2. mevetts
    mevetts
    Oct 31, 2003
    439
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    Try using the forums search facility and the term fx5.1 will yield several pages of threads for you
  4. Hamilton10
    Hamilton10
    I've got it. For £200 it's fine. I'm pleased with the satellites but the sub is the weak link (boomy). I'm going to replace the sub as soon as I can afford it. If you can stretch your budget further you might want to look at the Premiere Plus package from Mordaunt Short.
  5. simonph
    simonph
    May 21, 2002
    94
    yeah have been looking at that package.. is there a major difference between the avant and the standard 302s? gonna go for the bigger sub
