Tannoy fx 5.1 6 OHMS??
Discussion in 'Home Cinema Speakers' started by astonbilla, Jan 20, 2004.
  1. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Quick question (i hope)
    These speakers are rated at 6 ohms, my amp only has a 4 / 8 ohm selector. Which should i set it to, and why?
    Also i have the crossover set to 90 on these as my sony db940 doesn't seem to offer crossover at 80?? should this be ok?
    Bill
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    I think either will work but i would set all spoeakers to small and 8Ohm I think. Wont make a huge difference, Maybe someone else can shed more light on the situation.
  3. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Cheers for that!!
    strange thing though, i have a denon 3802 that can be set to 80 but the sony has 90 instead??!?!?
    so crossover is ok on either then? what does the ohm rating actually determine?
