Tannoy floorstanders, Can I mount them anywhere else than the floor ?
Discussion in 'Home Cinema Speakers' started by Taz69, Jun 14, 2005.
  1. Taz69
    Taz69
    Apr 15, 2002
    2,359
    Bristol
    +55
    Hiya all,
    I have a pair of Tannoy floorstanders 622D30s, however I would like to build a unit on either side of my firebreast to house my kit etc, is it possible to sit the Tannoys on top of the unit, I have them set to small I think on the amp as I use the Kef sub for the bass.
    Any advice welcome
    Taz :thumbsup:
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Wouldn't the tweeters fire about 5 feet over your head? Not so good for imaging. :(
  3. Taz69
    Taz69
    Apr 15, 2002
    2,359
    Bristol
    +55
    Didnt think about that, lol, but I was hoping to have the shelf sort of staggered if you know what I mean, about 12-18" high max for the speakers the unit for the hi-fi kit will be higher but that will be beside the firebreast, the speakers will be by the outside walls.
    Either that or can anyone recommend a pair of good replacements
    Taz
  4. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    A pair of matching MS bookshelf speakers?
  5. Taz69
    Taz69
    Apr 15, 2002
    2,359
    Bristol
    +55
    Hi m8, I think my mordaunts are the Declaration series not the Advants, is there any dis-advantage having the decs alongside the Avant 902 's for instance or do I need to go for the whole set of Avants ?
    taz
  6. Taz69
    Taz69
    Apr 15, 2002
    2,359
    Bristol
    +55
    Also, is it possible to use a 905centre for a rear centre for 6.1 ?
    Taz
  7. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    im using a centre for the rear in 6.1 and it works like a charm
  8. Taz69
    Taz69
    Apr 15, 2002
    2,359
    Bristol
    +55
    cool, sounds an idea then,
    Taz
