Fault is sound from tweeters only.
Both speaks when remove from cabinate show aprox 4 ohms - suspect crossover but cannt see one ? as terminal wires glued to base.
Is there cross over in these - does any one have the CCT or service manual? The plastic base plate seems to be secured with glue, is there any other fastners? Any tips to open or brut force?
Also when they stop working they took out my NAD 214 power amp both channels - have not yet look at that in detail - has any one any typical faults to look for - or recommend UK repair shop ( north wales area)
