stearman65
Established Member
Steraman65
Exif info.
Panasonic DMC-FZ1000
ƒ/2.8
- 9.1 mm
- 1/60
- 200
- Flash (auto, fired)
- Hide EXIF
- JFIFVersion - 1.02
- X-Resolution - 258 dpi
- Y-Resolution - 258 dpi
- Make - Panasonic
- Orientation - Horizontal (normal)
- Software - Adobe Photoshop Elements 10.0 Windows
- Date and Time (Modified) - 2016:06:20 11:02:57
- YCbCr Positioning - Co-sited
- Print IMVersion - 0250
- ISO Speed - 200
- Sensitivity Type - Standard Output Sensitivity
- Exif Version - 0230
- Date and Time (Original) - 2016:06:14 11:02:35
- Date and Time (Digitized) - 2016:06:14 11:02:35
- Components Configuration - Y, Cb, Cr, -
- Compressed Bits Per Pixel - 4
- Exposure Bias - 0 EV
- Max Aperture Value - 2.8
- Metering Mode - Multi-segment
- Light Source - Flash
- Sub Sec Time - 531
- Sub Sec Time Original - 531
- Sub Sec Time Digitized - 531
- Flashpix Version - 0100
- Color Space - sRGB
- Sensing Method - One-chip color area
- File Source - Digital Camera
- Scene Type - Directly photographed
- Custom Rendered - Normal
- Exposure Mode - Auto
- White Balance - Auto
- Digital Zoom Ratio - 0
- Focal Length (35mm format) - 26 mm
- Scene Capture Type - Standard
- Gain Control - Low gain up
- Contrast - Normal
- Saturation - Normal
- Sharpness - Normal
- Interop Index - R98 - DCF basic file (sRGB)
- Interop Version - 0100
- Compression - JPEG (old-style)
- Thumbnail Offset - 1372
- Thumbnail Length - 8134
- Application Record Version - 0
- IPTCDigest - e8f15cf32fc118a1a27b67adc564d5ba
- Displayed Units X - inches
- Displayed Units Y - inches
- Global Angle - 30
- Global Altitude - 30
- Photoshop Thumbnail - (Binary data 8134 bytes, use -b option to extract)
- Photoshop Quality - 6
- Photoshop Format - Progressive
- Progressive Scans - 3 Scans
- XMPToolkit - Adobe XMP Core 5.2-c001 63.139439, 2010/10/12-08:45:30
- Creator Tool - Ver.2.2
- Metadata Date - 2016:06:20 11:02:57+01:00
- Make - Panasonic
- Native Digest - 256,257,258,259,262,274,277,284,530,531,282,283,296,301,318,319,529,532,306,270,271,272,305,315,33432;C36A636BDDEA2490ED47DE04700B5934
- Format - image/jpeg
- Color Mode - RGB
- ICCProfile Name - sRGB IEC61966-2.1
- Instance ID - xmp.iid:F315BF29CE36E61194CB9D650F91A5AB
- Document ID - xmp.did:9782F084F335E61186FA8C7A5DBE7C6A
- Original Document ID - xmp.did:9782F084F335E61186FA8C7A5DBE7C6A
- History Action - created
- History Instance ID - xmp.iid:9782F084F335E61186FA8C7A5DBE7C6A
- History When - 2016:06:14 11:02:35+01:00
- History Software Agent - Adobe Photoshop Elements 10.0 Windows
- History Changed - /
- Viewing Cond Illuminant - 19.6445 20.3718 16.8089
- Viewing Cond Surround - 3.92889 4.07439 3.36179
- Viewing Conditions Illuminant Type - D50
- Measurement Observer - CIE 1931
- Measurement Backing - 0 0 0
- Measurement Geometry - Unknown (0)
- Measurement Flare - 0.999%
- Measurement Illuminant - D65
- DCTEncode Version - 100
- APP14 Flags0 - Encoded with Blend=1 downsampling
- APP14 Flags1 - (none)
- Color Transform - YCbCr View attachment 728513 View attachment 728513
- Camera ID - 72157643811934375
