Tangent D-400 DiVX DVD Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by sapper44, Jun 25, 2004.
  1. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    Called into my local Maplin store today.They have got this player Tangent D-400 DiVX DVD Player for sale in the shop and on line for £59.99.Has anyone got anything on this one here's the link. http://www.maplin.co.uk/
  2. Mumblesh
    Mumblesh
    Jul 2, 2004
    11
    4
    Luton
  3. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    Thanks for the reply.Have purchased this player and I am well pleased.
  4. mallyonline
    mallyonline
    I have also just purchased this item from maplin and highly recommend it.
  5. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    I have been using the player for a bit now.It is not perfect but none of these type of players are.I d/l a few films and it seems to have a prob with xvid. so I rencode the film using Dr divx and It has never failed to play all the way through.I also get the counter top left and have to remove it every time i watch an avi.I dont know if the problem's with xvid playback could be my media as I havent tried anything else.Anyway I still think it is a good player sound and pic very good, money well spent me thinks.
  6. jGrahamD
    jGrahamD
    Feb 11, 2002
    265
    Does anyone know if this has a 1.33 zoom setting, i.e., fill a 4:3 screen with the central portion of a 16:9 source (in the absence of pan/scan coding)?
  7. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    I am watching on a 4.3.Went to menu had three choises picked the one that fitted tv and that was it.
  8. jGrahamD
    jGrahamD
    Feb 11, 2002
    265
    If you set the aspect ratio to pan/scan and show a 16:9 anamorphic DVD that does not have pan/scan encoding, it will normally convert it to letterbox. Some DVD players have a zoom setting of 1:33 which effectively allows you to zoom in to the central region, thus recovering the vertical resolution but cropping the sides. That is what I was after.
  9. rd350ypvs
    rd350ypvs
    Jun 12, 2004
    52
    +3
    I have just received this player and for the money it is excellant. I put 2 mp3 folders, divx 3.11 avi and photos on a dvd and it played them all flawlessly, mix and match what you want, slam it on a disc and play, why can't all dvd players do that lol
    andyw
  10. jackuzi
    jackuzi
    Dec 3, 2001
    253
    16
    South Wales
    I have also bought one of these and I think it's a nice player. I have a problem thoguh that I'm trying to sort but not quite getting there.
    I have an MPEG1 avi that won't play so I thought I'd convert it to a divx5 (using Dr. Divx v 105). Once converted the audio was out of synch by just over 1 sec. Tried to work out what I'd done wrong but couldn't.
    I then installed virtualDub and re-synched the audio correctly. Trouble is the resulting file is MASSIVE ie 6 minutes = 9 Gb!! Where am I going wrong please peeps?
