Tamron AF 28-75mm f2.8 XR Di Zoom
Discussion in 'Photography Forums' started by seany, Jan 24, 2005.
  1. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    I've really been researching what lens i should buy for my 20D
    I've spent hrs on DP Review looking and comparing it to the Canon 17-40L and it has to be said that it's holding it's own. It gets fantastic reviews and many L owners have swapped over to it. I'm surprised to hear about the issues of ending up with a bad copy which is an issue for the canon and the tamron.
    The 17-40 is wider i know, i'm just thinking the tamron is the more versatile of the two, and from what i've read many don't believe the price difference is warrented
  2. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
  3. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    remind us again what lens you do have already?
    nice thing about the tamron is it leads nicely on to the 70-200mm telezooms, so you don't have a massive overlap.
    depends what sort of photography you do - I got the Canon 28-135 IS and am loving it - use it as my walkabout lens, have never been tempted to stick on the 18-55 since... point being, if you won't miss the ultra wide bit, then don't bother with the 17-40 L
  4. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Thank's fellas.
    I was checking that site Andrew the other day funny enough, which is making me more and more lean towards the tamron... I do like the idea of a wide lens but it's not too much of an issue at the moment and i like the extra focal length of the tamron
  5. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    TBH I copied it from a previous thread - took me an age to find it though....!!
    Still dreaming off the day I can convince er indoors that a DSLR is worth the expense.
  6. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Andrew, when my old dear asked me how much a lens was she said "are they about £150" :rolleyes: As we're one of those couples that keep all their money togather, we do consult eachother on things we buy, and though i could push for the 17-40 it would be a little selfish and i'm not sure the extra is warrented from the research i've done.
    But the way i am, i just might go and change my mind and go for the canon, which would mean Diane gets something if she wishes for round that price...It's how it works:rolleyes:
