Talksport not working with Chrome
Chris Jon
I hope ths is in the correct place
I have Windows 10 and I just did a small update. Since then, when I go to the Talksport radio website to listen, using the Chrome browser, I can't seem to click on the 'Play' icon/button. It's as if the icon/button is just a picture and not the actual play button itself (if that makes sense).
This happens when I use the Chrome browser, but with the Firefox browser it works fine.
I assume it's the Windows update that's done this, but not absolutely sure. I do know everything was working ok before the update
Any ideas what has happened?
Thanks all
sparky10
Thanks all
Hi, Try resetting Chrome, do this by going to settings/advanced settings and at the bottom of the page is 'reset settings', that may work.
Chris Jon
Ok thank you
I thought it might have been Ad Blocker because it worked when I turned it off but it's not working again. I'll try what you said though.
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
