Talking on a local network?
Discussion in 'Desktop & Laptop Computers Forum' started by Timh, Oct 31, 2004.
  1. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    I currently have 2 pc's setup on my local network and I want to be able to communicate by speech over the network, is it possible to setup WinXP proffesional (sp2) to do this, or will I have to purchase some software from the net?
    Thanks for any help
  2. stlic
    stlic
    Feb 17, 2004
    744
    +15
    Although you'll have to set up separate accounts and all PCs need to have access to the internet simply for authentication.. Free Skype software will work fine by routing the call directly and not using the internet bandwidth other then at authentication.
  3. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    you can use netmeeting to call over a network... thats still in win xp i think or its an easy download. Or you can use windows messenger or msn messenger if you have net access like with skype but they arent as good really.
    I dont know about any other programs but a search on google.com or download.com will probably find you something.
    Chris
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,108
    Manchester
    +713
    Actually Windows Messenger will do this - less complex a product than NetMeeting.
    It's part of WinXP pro but is also a free download from Microsoft for older OSes.
    Chris Muriel, Manchester.
  5. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,469
    Southampton
    +188
    Messenger
    Ventrillo
    Teamspeak
    These will all do it for free.
  6. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    Hi all
    Thansk for the help :) I have downloaded a free trial called ESDI looks basic but works for 100 Hours.
    I will take alook at windows messanger as it is already installed, why I never thought of that one I will never know :confused:
  7. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    For "out loud" chat as oppossed to texting I've found Skype to be far better than messenger, far less problems with hearing yourself coming out of the speakers at the other end.
  8. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    I am having that problem with edsi, there seems to be a couple of seconds delay as well which is annoying.
  9. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    I find Skype quite usable and its free.
  10. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    I looked at skype but its not really for local networks.
  11. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    I doubt it matters....
  12. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,469
    Southampton
    +188
    Ventrilo and Teamspeak are for local networks.
    Even when Ventrilo isnt on a local network I get around 20ms ping.
