Talismoon WhisperFan - replacement 360 fan.
Discussion in 'Xbox Forums' started by Tetlee, Jan 1, 2007.
  1. Tetlee
    Tetlee
    Jan 21, 2004
    20,319
    Taunton
    +4,817
    Just wondering how many of you have one of these fitted, I know I remember reading here ages ago that at least one person here had gone for it?
    http://www.talismoon.com/cgi-bin/version2/engine.pl?page=product-xbox360-whisperfan-blue
    Now that my warrenty has expired I'm very tempted to go for one of these, from the linked reviews on that site it sounds like a very good cooling upgrade & as it's now getting extremely hot out here in Argie, the cooler I can get my 360 the better!
    The thing is I'm pretty clueless as fitting this type of thing so would like to get opinions from anyone who has bitten the bullet & changed the fan as to how simple it is? I did change my Gamecube case over to a crystal one a year ago so hopefully it won't be any worst than that?
    Any thoughts or advise appreciated:smashin:
  2. Spooksta
    Spooksta
    Nov 7, 2000
    3,507
    Planet Earth
    +849
    Ive just ordered one off ebay (only £15 incl del) my 360 is in bits awaiting its arrival. Its very easy to do, just follow one of the many google found instructions. One thing though. They say you need to take the mobo out of the 360 but i didnt have to do that to get the fan tunnel and fan out.
    Took about 10 minutes to take to bits and could probably do it in 5 mins now.
    :thumbsup:
  3. filthy667
    filthy667
    Dec 19, 2005
    113
    Peterlee
    +7
    Ive got the blue led one fitted in my 360 with a clear case. Its a pretty easy job really,about 10 mins. The hardest part is opening the case of the 360,the fan just slots into where the old one was.
    The fan is quiter than the original and moves more air,it also looks nice all lit up blue:thumbsup:
  4. Waynej
    Waynej
    Oct 4, 2004
    8,070
    Wales
    +1,318
    Sounds tempting. The fans on the 360 are noisey but I'd be more interested in reducing the noise from the 360 DVD Rom.
  5. mortimar
    mortimar
    Jan 14, 2002
    45
    Northampton
    I've just fitted this fan to my xbox. Which was easy to do.
    Before I started I took a reading of the old fan using a SPL meter from about 1 foot from the front. I got a reading of 58db.
    After fitting New Whisper Fan I still got a reading of 58db :(
    I'm going to leave it a few days if it doesn't get quieter I'll refit the orginial fan.
    My xbox is a Dec 05 model
  6. Tetlee
    Tetlee
    Jan 21, 2004
    20,319
    Taunton
    +4,817
    Yeah, I did think to myself after reading about these fans....hmm, crystal case;)
    Any chance of a pic?
    Did you get the see through drive bay thingy aswell?
  7. Spooksta
    Spooksta
    Nov 7, 2000
    3,507
    Planet Earth
    +849
  8. filthy667
    filthy667
    Dec 19, 2005
    113
    Peterlee
    +7
  9. radiokid
    radiokid
    Oct 19, 2005
    121
    Leeds
    Did you measure the sound while you were playing an xbox360 game, becuase 58db sounds about right for the amount of noise generated from the dvd drive. Try taking the same reading with the old fans and then the new ones, but dont put a disc in, just stay on the dashboard.
  10. Bilbob
    Bilbob
    Feb 21, 2005
    4,587
    103
    Manchester
    +294
    has anyone tried fitting a speed controller to the fans? Seeing as they move so much more air than the originals, why not slow em down a touch, should reduce the noise from the fans considerably....?
  11. turk3y
    turk3y
    Dec 17, 2005
    3,249
    +1,034
    This might be worth reading then
    http://www.engadget.com/2006/12/06/xbox-360-quieting-mod/
    I am quite tempted, but its only 3db... I would have liked them to post sound clips so you can appreciate the difference before undertaking it.
  12. mortimar
    mortimar
    Jan 14, 2002
    45
    Northampton
    I took reading with no disc's in the drive only on dashboard.
    I'm only would like a quieter xbox so it doesn't annoy while watching a HDDVD
  13. Br0ken
    Br0ken
    Jun 13, 2006
    10,469
    localhost
    +1,314
    I'm used to sit 3m's from my xbox and never noticed its noise, now ive moved it up to my room its less than a meter away its quite noisey, i think i'll be changing the fan asap - i dont think im in warranty as i won the console lol
    Just had a look at that ebay link for the crystal case, i'd have to make the power button LED blue aswell, the green just clashes :)
  14. TankTopLover
    TankTopLover
    Aug 28, 2005
    4,158
    +190
    I fitted one ages ago,my 360 very rarely freezes now.Before i installed the talismoon fans i had far more problems.
    I recommend looking on the web for a decent guide to removing the case and take your time! It is a simple job but there is one fiddly bit on the rear :rotfl: Sounds dirty :oops:
    Anyway i can 100% recommend these fans,the noise decreases quite a bit,but more importantly,you can feel the difference if you put your hand to the back of the case,the air is HOT and you know the airflow is doing its job :thumbsup:
    I installed mine before my warranty ran out so i was a little nervous,but i am so glad i did it! Go for it mate :smashin:
  15. Tetlee
    Tetlee
    Jan 21, 2004
    20,319
    Taunton
    +4,817
    Think it was yourself slinky that I read about it from in the first place, one of your posts months ago.
    No need mate, they do green led fans aswell, red too if you're into that type of thing:rolleyes:
  16. lapino
    lapino
    Jan 17, 2005
    1,474
    48
    Oudenaarde
    +57
    Does anyone have a sound recording of the Talismoon fans working? I want to compare them to the "wiiirr" sound the DC Brushless fans make.
  17. Damien76
    Damien76
    Mar 10, 2009
    5
    I bought a Talismoon LED about 14 months ago for my old xbox just before it died so never got to install it.
    Bought a new xbox a few weeks later and have been waitng for the warrenty to expire.
    The warrenty is up now and went to install it today only to find Microsoft have changed the socket from a 4 pin to 3 pin.:mad:
  18. astar0th
    astar0th
    Mar 12, 2008
    6,205
    Mojave Wasteland: Holding Kav's hand
    +1,243
    A quick grainy pic i took last night with my iPhone:
    [​IMG]
    It still runs quite warm when playing a game from the disc (which is rare) so i have to press the switch for the fans to run at a faster rate.
    Playing from the drive, it's much quieter and cooler IMO.
  19. geowars2
    geowars2
    Jul 29, 2004
    651
    +22
    i don't have a recording, but i can tell you they are not any quieter. In fact i thought mines were louder!
  20. sordid_sentinel
    sordid_sentinel
    Mar 31, 2007
    2,062
    +487
    Do you have to do much extra work to get the fans running at the faster 12v rate (ie soldering cables etc)?
    I quite fancy some of these fans as my 3 year warranty runs out soon.
  21. astar0th
    astar0th
    Mar 12, 2008
    6,205
    +1,243
    I bought whispermax fans. They come with a pre-installed switch that sticks to the inside of the metal casing in front of the centre of one of the fans, if that makes sense?
    Basically, where there are holes in the plastic casing at the back, in front of the fans, you'll have a push button switch that changes it from normal to fast. I only use it when running a game from disk, which isn't often!
  22. sordid_sentinel
    sordid_sentinel
    Mar 31, 2007
    2,062
    +487
    Sweet, I thought to get the faster fan speeds I'd have to solder a wire onto the mobo somewhere to draw extra power. I'll definitely get some if that isn't the case!
