Taking control.
Discussion in 'Home Cinema Control & Remote Controls' started by Smokin..o0O, Jan 7, 2004.
  1. Smokin..o0O
    Smokin..o0O
    Dec 2, 2003
    145
    Scotland
    +9
    Hi.
    I think I know what I want, but I have no idea how to go about it.
    I want to control various bits of A/V kit.
    Plasma, amp/receiver, projector, and electric screen.
    Knowing nothing about the technology available to achieve this, and having read quite a lot on here about remote controls, I thought I should ask for help, and reduce my headaches :confused:
    I would also like to be able to control the low voltage lighting which I will be installing when I get round to hanging the new ceiling around the new DRH screen when it arrives.
    I hear the learning curve of managing the Pronto type remote is steep, but I think that's possibly the way to go.
    I guess the control of the A/V equipment should be quite straight forward, but I don't know if the control of the screen and lighting would be possible from 1 remote control.
    All I need to know is what kind of kit is required if it is possible, and I'll head off in search of it.
  2. shoehorn
    shoehorn
    Jul 2, 2003
    1,602
    The Garden of England
    +32
    As far as I know it's all "controlable" from Pronto - so long as you set it up correctly of course.
    This site is probably recogonised as the best for (you've guessed it) remotes.
