taking a player abroad
Discussion in 'Blu-ray & DVD Players & Recorders' started by chard, Apr 29, 2003.
  1. chard
    chard
    Dec 12, 2002
    398
    16
    I have a friend who wants to buy a multi region Philips DVD recorder (880) and take it to Spain to record and play DVD's and bring the machine back again.
    Will a multi region player in this country record Spanish TV or Sky recieved on a Spanish TV ? and is there any conflict with the power supply ?
    many thanks for your help....
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    Power supply will be no problem, you'll just have to fit a different plug or use an adaptor. The DVD recorder should record perfectly well from the Sky Box as well (via scart).
    Only POSSIBLE problem may arise if trying to record a terrestrial tv signal from a Spanish TV via the RF ariel socket/input. You MAY get no sound unless the dvd recorder can cope with any european sound carrier (PAL I, B, G etc)
    Standard UK TV's can't pick up the sound for terrestrial Spanish TV as it is broadcast at a different frequency. Likewise, via RF, a Spanish TV won't work with a UK video and vice versa. Using Scarts overcomes this.
  3. chard
    chard
    Dec 12, 2002
    398
    16
    Jase,
    many thanks, just one question, are you saying that the recorder should be able to record off a Spanish TV using a scart ?
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    Depends on the TV model, some will let you record whatever happens to be on the screen at that time. Usually TV's with multiple AV sockets though.
  5. chard
    chard
    Dec 12, 2002
    398
    16
    great, Jase, thanks very much for your time and replies here...
  6. mjn
    mjn
    May 24, 2001
    22,102
    Herts, England
    +9,855
    if you can get some kind of tuner box or VCR, this will do a conversion. so you just use the SCART on the VCR to the recorder.
    Thats how i use my UK spec TV in Ireland.
  7. sinbrad
    sinbrad
    For Chard
    Just to let you know that if you intend to record from a Spanish television via scart you will not be able to change the channel as you will only be able to record what is actually being shown on the television at the time and also the television will have to remain on throughout the whole recording. Found that out when recording from Portuguese television!!
