TAGTronic Sync Link
Discussion in 'TAG McLaren Audio Owners' Forum' started by tjobbins, Aug 15, 2005.
  1. tjobbins
    tjobbins
    Jan 1, 2005
    157
    16
    Harpenden
    Me again with my newbie Tag questions.. :)
    Just reading the AV32R DP manual online (it's my porn until I can get the real thing :D )
    Noticed something which may be of benefit to me.. TAGTronic Sync Link.
    I have only one digital source - my HCPC. From this I play both music (stored lossless, not MP3) and DVDs. I use a Echo Audio MIA 24/96 pro-audio sound card, with a SPDIF connection to the pre-amp.
    The Echo Audio has the ability to sync to an external clock via its SPDIF input.
    Therefore this suggests to me that I can connect the TAGTronic Sync Link output to the SPDIF Input on my Mia, and thus reduce jitter? Is this how it works?
    On the subject, the Mia manual says:
    Your Echo digital audio system can only sync to S/PDIF clock if the
    master device is set to a sample rate between 30kHz and 50kHz. Otherwise you will get noise and/or loss of sync.
    Would this suggest that I will be fine when playing 44khz audio, but will get problems if, for example, I try to play a DTS 24/96 stream?
    Thanks!
    Tom
  2. bushy30
    bushy30
    Apr 8, 2005
    432
    Oxon
    +9
    Hi Tom,
    Search the forum again, someone asked this not long back, I think the answer was that the TAG system was excatly that -- a TAG system and not compatible !
    Bushy
  3. tjobbins
    tjobbins
    Jan 1, 2005
    157
    16
    Harpenden
    Thanks bushy, I should've searched first!
    I am still not sure I have the answer tho. I have found a recent post where someone asked exactly the same question as me, but there's no conclusion to it, just some people going to try it out.
    However I have found other posts where the Sync is clearly referred to as an analogue signal; this immediately implies it wouldn't be compatible with an SPDIF input on my soundcard.
  4. bushy30
    bushy30
    Apr 8, 2005
    432
    Oxon
    +9
    Errrrrrrr yes
    I believe that is the case (being analogue that is !)
    Bushy
  5. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    It will not be compatible.
  6. tjobbins
    tjobbins
    Jan 1, 2005
    157
    16
    Harpenden
  7. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    tjobbins.
    It may be wise (should you decide to buy a DP) to do some serious reading and trials with TMREQ as it is not exactly plug-n-play.
    Steven
  8. tjobbins
    tjobbins
    Jan 1, 2005
    157
    16
    Harpenden
    I've already started reading - read through UrbanT's PDF guide, and will tackle the whole TMReq thread next.
    I like a challenge!
