TAGTronic protokol
Discussion in 'TAG McLaren Audio Owners' Forum' started by Patrick, Dec 4, 2004.
  1. Patrick
    Patrick
    do enyone has a TAG Tronic protokoll for an AV192R.
    Tanks
    Patrick
  2. crestron boy
    crestron boy
    Nov 30, 2004
    726
    Woking
    +40
    would you be trying to integrate with crestron or amx by anychance
  3. Patrick
    Patrick
    I want to take a lock on the protokol. If it is usefull to handle the AV192R i will wrap it into WIn32 COM so everone can handle the AV192 in VB C# or C++.
    So I neet to see the protokol first to decide if there is any change to do this.
    Bye
    Patrick
  4. JohnMulcahy
    JohnMulcahy
    Jun 13, 2004
    181
    Aldershot
    +20
    Low level protocol doc attached
  5. JohnMulcahy
    JohnMulcahy
    Jun 13, 2004
    181
    Aldershot
    +20
    And here are the message definitions
  6. Patrick
    Patrick
    ohha,
    this is a hard staf. I will sit down and read it.
    Tanks
