Tagtronic control
Discussion in 'AV Receivers & Amplifiers' started by trevsorbie, Sep 12, 2007.
Tags:
  1. trevsorbie
    trevsorbie
    Feb 23, 2005
    50
    I'm attempting to write an application to control my home cinema from a computer. Does anyone have any code that conforms to the Tagtronic protocol (including handling the CRC stuff) to get me started?
    I'm probably writing in Java but any code would help me.
    Many thanks
    Trev
  2. benzol
    benzol
    Mar 16, 2005
    385
    Europe
    +22
    Please have a look in the FAQ
    It's under "IR REMOTE CODES AND TAGTRONIC PROTOCOLS"
    There have been several attempts to do what you are planning, but it never surfaced again. So if you have found a solution it would be great if you go public with the developments.
    Benzol
  3. trevsorbie
    trevsorbie
    Feb 23, 2005
    50
    Thanks Benzol
    I did get a simple implementation working that just selected the input source and adjusted volume levels.
    That was about six years ago and I no longer have the code or the Excel spreadsheet I originally used to visually calculate the CRC codes for each message.
    I recently tried to calculate the code for the PING message but I couldn't get the received CRC to be 0x1D0F! I'm curious if anyone had managed to get the CRC calculation stuff to work to save me the bother :)
  4. babaroga
    babaroga
    Aug 27, 2003
    220
    Hertfordshire
    +4
    I have some code that i have got from SteveSky on this forum that has been written in JAVA....Now, if i have time to modify it....
    If steve is still here, I would need his permission if the code could be passed on, or release it as Open Source, now that IAG has ditched Tagtronic...
    regards
    darko
  5. Miron
    Miron
    Sep 26, 2002
    1,439
    Vienna, Austria
    +56
    bit off topic,
    as far as i can remember (and i am meanwhile so old that i can't rememeber anything anymore :D ) Steve was one of the very first people who wrote their application using TAGTronic protocol, even before he started at TMA.
    also, benzol, there were quite a few people who succesfully wrote their own applications talking to TAG units. A friend of mine still has his PC controling his AV32R with SN under 100.
  6. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Highly unlikely it's from me.... I don't do Java stuff! Probably more likely from John Mulcahy as he did a bit of work in this area for the TMREQ setup wizard.
    All the TAGTronic protocols were documented by TAG, they were just a bit tricky for Joe Blogs to implement, due to its multi-point nature (so bus arbitration is required) and all the messages are packetised, so CRC's etc. need to be calculated.
    From memory the TMREQ stuff assumed that it was working Point-to-point (so no bus arbitration issues).
    Steve
  7. babaroga
    babaroga
    Aug 27, 2003
    220
    Hertfordshire
    +4
    Steve,
    Can you speak to John then and ask him if can share the code, please ?
    regards
    Darko
  8. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    John Mulcahy is a member of these forums. Do a search involving TMREQ and you will find posts from him.
    Steve
  9. babaroga
    babaroga
    Aug 27, 2003
    220
    Hertfordshire
    +4
    ooops, I have mixed up quite a few things, D'OH...
    Code has actually came from Chris Skates...now if Criss is still around...
    anyone ?
  10. babaroga
    babaroga
    Aug 27, 2003
    220
    Hertfordshire
    +4
    I just got mail from Chris Skates and he told me I can share the code with you guys under condition that he get what we make out of it :) fair deal....
    regards
    Darko
  11. trevsorbie
    trevsorbie
    Feb 23, 2005
    50
    Sounds fair enough to me; I don't mind making this open source.
    Please let me know where I can download the source that Chris has and I'll get started :)
    Trev
  12. babaroga
    babaroga
    Aug 27, 2003
    220
    Hertfordshire
    +4
    Trev,
    I think that we can pull away this one together. That thing from Chris is nearly finished, but I had idea to clean some code and also make a "webservice" out of it, so you can "shoot" xml to it in a format like:
    <TAG>
    <device name="av32r" id="1">
    <value>av32r</value>
    <volume>
    <up>
    <value>10</value>
    </up>
    </volume>
    </device>
    <TAG>
    Jetty would be the choice of runtime for it.
    PM me your email address please.
    regards
    Darko
