Tagmclaren DVD32 FLR Multiregion Hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by tedy, Oct 8, 2003.
  1. tedy
    tedy
    I read on the reviews for Tagmclaren DVD32R that it is hackable for multi region, however I did not find anything on the database.I own a DVD 32FLR which videowise is the same as the DVD32R.Does anyone know how to hack it?
  2. Anodyne
    Anodyne
    Dec 4, 2002
    552
    46
    Bristol
    +134
    734 and then the Region Code you need with the tray closed with no disc.
  3. tedy
    tedy
    Thanks.However I have to ask two more questions .
    1)I have region 2 .If I press 734 and then 1 ,I will have region 2 and 1 permenantly or do I have to go back and forth each time.
    2)I have read in the past that some DVD players that were region hacked after a while they were locked.Since it is an expensive DVD player I hope there will be no problem whatsoever by doing this.
    Thanks in advance.
  4. Anodyne
    Anodyne
    Dec 4, 2002
    552
    46
    Bristol
    +134
    The best thing to do is set it to region 0 and then it'll play anything.
    As far as I know they'll be no problem doing this, mine has played everything without any trouble.
    Hope this helps!
  5. tedy
    tedy
    Thanks.
