TagmcLaren AV32DP192 with DSS threnntranfo
Discussion in 'TAG McLaren Audio Owners' Forum' started by muziek, Jul 26, 2005.
  1. muziek
    muziek
    Hello,i buy an threnntranfo.This gives 240 voltand 50 hz in the threnntranfo outlet.Can i consume this outlet with the Tag pre amplifer.The other outlet without threnntransfo gives 280volt.Can i without problem use.Thanks.
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    What current can the transformer supply? Best ask the IAG helpdesk really as I have no experience of that model at all.... I would say that you should NOT use the 280V outlet to power the AV192R though as that is way over the spec for the unit. What is your normal house supply voltage?
  3. muziek
    muziek
    I'm from Belgium and the voltage now is 228.I tested this with an voltagemeter.This tranfo gives an constante ohm and voltage
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Why don't you just plug the AV into the standard wall socket? It should be fine.....
  5. muziek
    muziek
    I'm Wrong whit the other outlet it's give not 280v it gives 228volt.I 'm from Belgium.
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    I would suggest that 228V is perfectly fine for any TAG gear.....
