tag upgrade cable query
Discussion in 'AV Receivers & Amplifiers' started by AMCross, Jun 25, 2015.
Tags:
  1. AMCross
    AMCross
    Dec 3, 2003
    6,066
    Livingston,Scotland
    +217
    i have two of the standard 9 pin d plug type
    anyone know if the standard lead can be modified as my av192r has the front panel and i would like to use one of them on this
  2. david1961
    david1961
    Nov 8, 2005
    257
    melbourne
    +27
    Hi AMCross
    Cant help you with the lead
    But thought you might be interested in an Aphrodite on ebay at the moment
    I recall you looking for non working tag gear
    David
  3. karlknurr
    karlknurr
    Aug 19, 2012
    240
    +23
  4. Rjpcardoso
    Rjpcardoso
    Jun 3, 2013
    326
    Wokingham
    +18
    Hi AMCross,
    Yes it can be modified. i have made one myself.
    Are you still looking for this or have you sorted already you problem?
  5. AMCross
    AMCross
    Dec 3, 2003
    6,066
    Livingston,Scotland
    +217
    well thanks i will now convert one of my normal ones
  6. AMCross
    AMCross
    Dec 3, 2003
    6,066
    Livingston,Scotland
    +217
    thanks david placed a bid whilst on holiday and got back and its disappeared
