TAG Sync Link
Discussion in 'TAG McLaren Audio Owners' Forum' started by mark67, Oct 21, 2003.
  1. mark67
    mark67
    Does the quality of the cable make any difference when plugged into the Tag Sync link?
    I know using it is meant to reduce jitter, I do use it between my Tag CD Transport and my AV32 Processor. I just wondered if the cable quality have any effect on the sound?
    Cheers.
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    All it needs to carry is a analogue timing signal. Just use a good quality screened analogue lead and you should be fine.
