Tag Service
Discussion in 'TAG McLaren Audio Owners' Forum' started by pnm, Dec 7, 2004.
  1. pnm
    pnm
    Feb 6, 2002
    87
    Shropshire, UK
    I purchased a T20 Tuner directly form TAG 02-2003 and a part of the display has developed a fault (it's gone very dim). As the unit came with a manufacturers 2 year warranty it should be coveredso I would appreciate it if someone could point me in the right direction for service now Tag is no more?
    Thanks for your help
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
  3. pnm
    pnm
    Feb 6, 2002
    87
    Shropshire, UK
    Many thanks
  4. jbm007
    jbm007
    Then Expect To Wait 3 Months For A Repair To Be Completed
  5. Polecatpete
    Polecatpete
    May 12, 2004
    445
    +5
    I personally think IAG have been brilliant. Considering the amount of work they have had to get through, turn around times are reducing all the time.
  6. edward
    edward
    Apr 2, 2003
    858
    32
    Reading
    +26
    Ouch!
    All of my processors have been absolutely fine. With the possible exception of the DVD32, its reliable kit.
    Spoke to the service desk the other day (OK, I had to phone them back) and the man was really helpful - knew what he was talking about etc.
  7. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Don't suppose the T20 has a varible brightness VFD like the other kit and therefore pressing the display button would brighten it up?
  8. pnm
    pnm
    Feb 6, 2002
    87
    Shropshire, UK
    Thanks for the suggestion. The T20 is based on the Audiolab 8000T and has an older type display with no adjustments (not even off!).
  9. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    The display semi-off and off is implemented as the back light bulbs slowly blow! :D
  10. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Sounds far less complicated than your software programming :rotfl: :rotfl:
  11. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
    But you have to admid it was fun Harr(i)assing Steve to get the blue LED brighteness from all equipment in line......... :D
  12. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    He forgot the Scaler PSU LED though....... ;)
