TAG Remote problem
Discussion in 'TAG McLaren Audio Owners' Forum' started by Parmenion, Apr 22, 2005.
  1. Parmenion
    Parmenion
    Feb 6, 2002
    1,258
    Out there
    +50
    Is there a reason why a remote control from an older AV32R would fail to control a newer DP version?
    Is it a matter of different IR codes or do I need to "assign" the old remote to the new machine?
    Some commands are accepted, like which input is selected, but volume control and switching on and off just don't work :(
    Anyone have any ideas?
    regards
    Parmenion :lease:
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Try new batteries?
    Actually there was a slight change in labelling on the newer remotes, maybe some re-coding was done but I doubt it.... I assume you don't have the child lock enabled?
  3. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    RC5 codes are exactly the same as the 32SP. As Graham suggested replace the batteries and if all else fails do the learnt commands reset sequence, can't remember it, look in the 32R manual, it's near the back.
  4. TaxHamster
    TaxHamster
    Jul 8, 2004
    39
    11
    +10
    See attached for remote reset details...
