Tag remote macro
Discussion in 'TAG McLaren Audio Owners' Forum' started by caleb, Sep 29, 2004.
  1. caleb
    caleb
    Sep 30, 2003
    368
    Cape Town (Ex Holmfirth Yorkshire)
    +3
    Can anyone help me?
    I have the TAG remote and want to put in a macro to turn o several pieces of kit with one button press.
    Trouble is when I follow the instructions in the booklet - it doesnt work.
    I remember something about this on the old site where toi book was actually wrong - can anyone help me - Graham you are the expert and I would appreciate your knowledge here.
    Regards
    CBW
  2. sijones
    sijones
    Nov 5, 2001
    587
    Reading
    +29
    Hi Caleb,
    I have never needed to program macros into the TAG remote but I thought it may help you if I post the text from the latest AV192R manual for macro programming. Just in case the instructions you have are incorrect. See below. I suggest you create a very simple macro as a test.
    Regards,
    Steve
    To program in a macro function:
    1. Simultaneously press the REMOTE SELECTION key for the set of
    macros you wish to program (av or sat) and the mute key. The
    learning status LED and the REMOTE SELECTION key will both
    turn red to indicate that the remote is in macro learning mode(1).
    2. Press one of the macro keys m1 to m4 or standby to which you
    wish to allocate the functions.
    3. Press the keys for the commands (up to 10) you want stored in
    the macro key(2).
    4. Press the VIDEO + (or VIDEO -) key to store your selections. The
    flash red twice, then go out.
    5. To use the macro, simply press the macro button.
  3. TaxHamster
    TaxHamster
    Jul 8, 2004
    39
    11
    +11
    In step 4, the keys used will be labelled "CH+" or "CH-" (to the right of the Vol keys) on older remotes.
  4. caleb
    caleb
    Sep 30, 2003
    368
    +3
    Thanks for the reply to my query, and the instructions from the book.
    These are the same as I have been trying over the past months, but when I do EXACTLy as it says, the macro only remembers the first instruction, and no more.
    I have taken the remote to my TAG dealer and he cant get it to work either!!
    I do remember at one stage a slighjtly different routine for the programming which worked, but then I changed my batteries and lost the macro!!! :rolleyes:
    Oh well, I suppose that I will have to revert to pressing four buttons instead on just the one - what a drag.
    Thanks Again
  5. Plump
    Plump
    Feb 22, 2002
    636
    19
    under the bridge
    that will teach you not to change the batteries, never ever again :)
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Not in this case mate......Like Steve I never used the "feature" on the TAG remote, along with just about everybody else, I use a Pronto....
  7. canavan
    canavan
    May 30, 2004
    103
