Tag owners please
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by johnson, Feb 11, 2002.
  1. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    I'm the proud owner of a new avr32r and 100*5.
    When switching to standby with the tag link in place the blue light on the processor goes very dim,but the blue light on the amp stays bright.
    Any thoughts?
    The amp has switched off.All the red channels lights go off.
    The processor has software 3.5.Not sure how to find what software the amp has.
    Also in the setup I have the mains set to bass limited.Just because I want to crossover to the sub at 80hz when watching movies.When playing direct mode,are the mains receiving a full range signal or still everything above 80hz?
    Regards
    Simon
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Simon
    The best place to ask about Tag is at there website but to help..
    In the set up option on processor go to the Tagtronic section. If the amp and processor are connected via the bus the processor will communicate with the amp and give you software version number. You will need 3.5 for full control of the blue LEDs on both processor and amp. This can be done either via your own programming cable or the dealer will be able to help. It should take no more than 5 mins. When both are running 3.5 you will have loads more control over the LEDs, virtually unique in my experience. Actually really useful being able to dim LEDs in AV rooms.
    Re where the bass goes then look at the Tag website for some postings by Joel around christmas 2001. He wrote a small article on it all. If you have problems finding the posts let me know.
    Welcome to the club.:cool:
  3. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Nic,
    Thanks for the reply.
    I've looked in the tagtronic setup but cannot see anything for the lights.
    However,it did confirm both the processor and amp are ver.3.5
    I'll have a look on the Tag-forums.
    Many thanks
    Simon
  4. RC
    RC
    If you want, I can give you a copy of Joel's AV32R bass management doc. Just let me know.
  5. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    RC
    Yes thanks, I would appreciate that.
    Have you seen the avr32 upgrade today on the Tag web-site?
    Looks tempting!
    Regards
    Simon
