Tag McLaren DVD32flr - Compatability with re-writable discs
Discussion in 'TAG McLaren Audio Owners' Forum' started by g man, Apr 21, 2005.
  1. g man
    g man
    Looking for some help here, I have just purchased a Tag Av32R SP192 and a 5 channel remote Tag power amp. The natural choice of DVD player would be the Tag but as I record a lot of tv on a dvd recorder(Sony + and - rw but without time slip as a rather primitive model unfortunately) I require this new purchase to work in conjunction with this machine. My little lady has ruled out an upgrade on the recorder and is not agreeing to Sky+ the two obvious solutions. I therefore require this machine to be preferably compatible with both re-writable formats but from reading reviews, checking the spec on the IAG web-site and speaking to dealers who dealt with Tag products it seems to be a resounding no it will not play them.
    Please help! :lease:
    No, I will not get rid of the little lady.
  2. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
    All I can tell you is that my late build (S58) DVD32 plays all recorded discs (so far!) perfectly - Verbatim + Taiyo-Yuden +/-R, Verbatim +/-RW, Philips +RW, TDK -RW and Verbatim +DL all recorded with Plextor PX-716A played with any hint of a problem.
    As I understand it ALL DVD32FLR have the late type (S58) mechanism so all FLRs should play all recordable disks (that are properly recorded) except DVDRAM.
    Edit - Taiyo-Yuden CDR, Verbatim CDRW are fine with audio too, remember that the DVD32 (either type) doesn't play VideoCDs.
  3. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,346
    Livingston, Scotland
    +225
    G-man
    My FLR plays vothe + and - discs. Brands that I have played include TDK, Maxell, Ricoh, Datasafe, Datawrite, Platignum etc etc etc :thumbsup:
  4. Spen69
    Spen69
    Hi G-Man
    Can I just check - are you trying to play re-writable DVDs on the unit? If so, I doubt it and have never tried frankly as DVD-R media is so cheap now, why bother?
    As all the other guys are telling you, I can confirm it will play any disc I've thrown at it, and some of the discs I had with errors on them from my early burner (threw it away at last!) it also seems to have no problem with. I used to have to use expensive +R's, but those days are long gone now I have the FLR :D
    My current weapon of choice is a Sony 12 speed burner on my pc and Bulkpak -R's (the 8x orange ones). Works every time, and stupidly cheap but cracking quality discs. I always trim the file sizes to 99% of the disc capacity to avoid errors at the very edge of the discs which is where my old burner went wrong, so it's just an old habbit... :rolleyes:
    The FLR will play them all mate, so get your hands on one before they're all gone :clap:
