Tag Mclaren DVD digital DVI feed
Discussion in 'Blu-ray & DVD Players & Recorders' started by abspag, Apr 30, 2005.
  1. abspag
    abspag
    Please help Tag Mclaren DVD digital DVI feed Can I use the dvi feed with a projector if the projector has HDCP if not :lease: does anyone know a way around this ?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    OK i think you are a bit confused, if the PJ DVi is HDCP capable then all DVi_D inuts will work (as long as they matched acceptted res for PJ) its only a problem the otherway round, ie no HDCP input on PJ then you need a work around..
  3. abspag
    abspag
    Thanks for the reply So it should work ok then ?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    yep as long as display accepts the res and refresh the TAG outputs.
