Quantcast
Tag McLaren DPA32R Remote Codes , Help required
Minuno
I have a Tag McLaren DPA32R Pre Amp but haven’t got the original remote for it, I do have a Logitech Ultimate Universal Learning remote, could anyone who has the remote DPA32R and a Logitech remote please upload the missing codes to Logitech’s servers?, the codes that are missing are
menu
Return
Enter
Cancel
these are needed to access the set up menu for this pre amp.
any help appreciated .
Minuno
I don't have the codes but there is a dpa32r original remote on ebay
Thanks I did see that one, I was hoping to not have to spend that on a remote, when I can control 90% of the functions with the Logitech. I’ve just bought that one in eBay, as I really need to access the menu to turn on the synch link and other settings. I will attempt to add the missing commands to the Logitech database, so that others in a similar situation who buy this amp without a remote can benefit from full function.
david1961
Hi Minuno
Was a very limited menu on the dpa32r I thought
I have one and have found that it sounds best with high power amplication
How have you found it ?
David
karlknurr
Attached please find the remote control codes for the DPA32R
Minuno
Hi Minuno
David
it sounds excellent with both the 250 and 100 Tag Amps, it will I feel sound better with the 250 as it’s a higher quality power amplifier I feel. It’s a great Pre Amp and I feel one of the best Tag offerings as it has the best of both Worlds dac and analogue combined.
