Hi all!
So I was searching the internet to find a solution to my problem when I found this forum.
It's my first time, so I'm sorry if something is wrong with my first post.
A few years ago I bought a TAG Mclaren Aphrodite. It worked very well for many years, but one day it decided not to work anymore. I sent it to the UK to have it repaired. It arrived perfect, but a few months later the problem persisted. I sent it to the UK again but they told me there were no more parts available so it was no longer possible to repair. So I decided to buy a new used one. I bought one in Belgium. The only defect is the display that keeps flashing when the system is working. When it is off, the display does not flash. Also, the brightness is very low when the system is on or off. So I decided to replace the "new" display board with the older one that was working fine. Surprise! The other display is also flashing on the new system. So the problem is not the display board, but the motherboard.
I think there is a converter that cannot supply enough power to the display board when the system is working.
Does anyone have an idea what the problem could be?
Does anyone have the schematic?
I'm trying to fix the display problem first, before fix the other system (the one that doesn't work).
Thank you all!
Thank you all!
