Tag DP with Dolby Headphone
Discussion in 'TAG McLaren Audio Owners' Forum' started by highlander_777, Nov 5, 2004.
  1. highlander_777
    highlander_777
    Apr 4, 2004
    216
    Question to owner of a TAG AV32 DP with Dolby Headphone installed
    I assume that the socket is in the back of the unit. If that's the case, what headphones do you use and what is sound quality like?.
  2. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    No socket at all (unfortunately) :(
    Headphone preamp is needed. You can use either tape out or second zone (Ex outputs) if you have 7.1 . Most users use diverse X-Can generations if I recall it correctly.
  3. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
  4. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
  5. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Could you ever see TAG putting such a naff label on the back of their kit, besides where is the "wellie" to drive a pair of cans? Certianly not a standard feature......
    I'd be a bit wary especially considering the revue's point to a DP....
  6. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
  7. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    Well my link doesn't work
    But can you remember the person who was asking if anybody knew what his NEW unit was worth
    Someone suggested that they lived nearby and could pop in and help
    The unit was described as PRE production
  8. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    found the original thread:
    Hi Everybody,
    I'm new to the forum and I have not just joined to flog the below unit
    I had a mutiroom audio set up with control system etc installed a while ago but half way through installation I changed the spec. I have been sitting on 1 x Tag AV32R SL surrond sound amp in black for a while now but I need to let it go!!
    This unit is fully boxed and has never been used it has remote, power cable and full instruction manual. It is black in colour. The unit cost around £2000.00.
    Since it is in A1 condition I will be looking for a price around £1500.00
  9. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Like I said if it was a pre production SP and that label actually does what it says I'd stay well away unless the chap comes clean and actually describes the unit on offer.......
  10. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    BTW, you need more memory in your HTPC...... ;) I'd have picked the 6600GT PCI-e card as well......
  11. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    Ps GrahamMG
    I wish i could afford more memory :laugh:
    But then again i thought XP pro levelled out with more than 512MB
    My Intel 875 rig with 1GB DDR400 did not feel any quicker with the extra ram when i updated it
  12. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Every little helps..... :D By the time you get to 2Gb it levels out.... :D Mind you an overclocked 3.6Ghz 775 is still running at 100% with some hefty processing turned on..... I'll have to go back to using the VSM2048...... but the big question is what res should the PC output into the VSM........New thread beckons....... :offtopic:
