TAG AV32r
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by mark67, Sep 24, 2003.
  1. mark67
    mark67
    Can someone tell me how I would connect the rears and centre speaker on this machine. I have looked at the back of the machine and the centre and rear outputs are Phono. I would have thought they should be speaker terminals?
    Bit confused :confused:, Can someone shed some light on this matter?
    Cheers.
  2. nathan_silly
    nathan_silly
    Have you got a poweramp?
    The Tag AV32R is a processor. The low level outputs (phono) plug into a multi-channel power, and then you connect the speakers to the poweramp.
  3. mark67
    mark67
    No all i have got is a 2 Channel Power amp.
    Do i need another?
  4. nathan_silly
    nathan_silly
    Yup. At least a 3 channel (to go to 5.1) - for the centre, stereo rears.
    Or a 5 channel to go into 7.1 - for the centre, stereo rears, stereo sides.
  5. mark67
    mark67
    Bugger.
    I thought you could use it as an add on processor? Guess not.
    At present i have got an old Yamaha that is an addon- processor ,
    Centre and rears only and that is fed by my Pre amp. I thought the tag was a similar set-up.
  6. mark67
    mark67
    Does anyone know an Add-on procesor that has PL2?
  7. rob@rar.org.uk
    rob@rar.org.uk
    Apr 29, 2001
    343
    16
    Hampton, Southwest London
    Mark, why would you want to buy an add-on processor? In your AV32R you have a fine processor which will provide you with top quality 2-channel and 5.1 channel audio processing. You will have access to Dolby Digital, DTS, PL2, THX processing, etc, etc. Why would you want to look for an add on to provide ProLogic 2?
    Regards
    Rob
  8. nathan_silly
    nathan_silly
    I wouldn't sell the Tag and buy a AV amp- the Tag will have better sound quality & processing than a AV amp.
    See attached pic on how to set up your system. You'll need a 3 or 5 channel poweramp. Fork out for a 3 (or 5) and you'll have a better system.
    What have you got already?
  9. mark67
    mark67
    At present I have got A belcanto Power Amp 2 Channel.
    I haven't got the TAG yet, I ordered it today and I didn't realise that I needed a 3 Channel amp to run it. I cannot afford to buy the TAG and then go out and get a 3 channel amp as well. Wish I could. That the situation I am in at the moment. So i am looking for another (and cheaper way of ugrading the AV part of my HIFI.
    Cheers.
  10. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    mark...how did you manage to invest in a machine of that price without knowing what you would need to use with it....quality-wise there's a world of difference between the Tag and the Yamaha....you best bet would be to go for at least a 3 channel power amp,preferably a 5 channel one,keeping the Tag,which is an excellent processor at the price.
    What is your current amp and speakers?
  11. nathan_silly
    nathan_silly
    That pictures for a 5 channel poweramp setup- since you have got a 2 channel amp- just move the front pair (left right) to the 2 channel poweramp.
  12. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    Ok...what sort of budget would you have to work on,mark...there are several options in terms of secondhand amps that would be perfectly suitable if funds are tight.
  13. mark67
    mark67
    Pardon my Ignorance Nathan,
    But I don't get what you mean by: since you have got a 2 channel amp- just move the front pair (left right) to the 2 channel poweramp.
    I already have got my Power amp running the Front L/R.
  14. mark67
    mark67
    Alexs2,
    Give me some examples and I'll let you know if they are in my price range.
    Cheers.
  15. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    There are quite a few Linn power amps around at present,from about £300 up secondhand...would that be suitable...also some of the Arcams
  16. nathan_silly
    nathan_silly
    OK- ignore the earlier pic (that was for a 5 channel poweamp)
    See new pic for you system- a 2 channel plus a 3 channel (or a 5 if the last two are unused)
  17. mark67
    mark67
    Mmm, Don't really want to be changing my Power amp. I have only had it about 3 months and am quite attched to it.
    Sorry for being so negative.
    So as I said before could I use an AV amp as a processor. Bit of an overkill i know, but I cannot find a Processor I can add on and keep my 2 channel amp.
  18. nathan_silly
    nathan_silly
    Why should you need to change the 2 channel poweramp? Just buy poweramps for the remaining channels.
  19. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    Thin you misunderstood what I was suggesting...and nathan's comments also....neither of us are suggesting discarding your existing amp,but you do still need amps for the remaining 3 channels....
  20. mark67
    mark67
    Wow Nathan,
    Love to, but funds won't allow.
    Unless you know a cheap amp that would be suitable?
  21. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    Mark....if you give either of us some idea of the budget you have for additional amps we might be able to help....
  22. avanzato
    avanzato
    Jan 21, 2003
    1,940
    Norfolk
    +77
    This brings up a point. I've always thought that adding the processor title was a confusion and products like the TAG, Arcam AV8 etc. should be called AV pre-amps only.
    You should be able to pick up a Rotel multi channel power amp for under £300 S/H
  23. mark67
    mark67
    Ok, How about £300. After getting the Tag (IF) Funds would be very Low.
    Would it have to be a 3 Channel Amp?
  24. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    It would have to be a 3channel amp,yes....the Rotel amp that avanzato mentioned would be ideal....fits the budget and also sounds pretty good.
  25. mark67
    mark67
    Any others?
  26. nathan_silly
    nathan_silly
    I would buy a 5 channel poweramp- it'll allow you to add more speakers to go upto 7 channel (if you upgrade your Tag processor to 7.1 version) or you could use the the fourth channel biamp the centre.
    The 3 channel Rotel poweramp is very hard to get hold of- the 5 channels are much easier to find. Something like the Rotel RB-985 Mark II would be a decent purchase.
  27. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    nathan...mark's already indicated his budget here.....it would be ideal to have a 5 channel Bryston or a set of Krells...but.....
    It's definitely worth looking on ebay and www.ex-dem.co.uk and www.loot.com for the Rotel amps.....i can't think of much else at the price that compares.
  28. nathan_silly
    nathan_silly
    Yeah but the Rotel 993 (the 3 channels) usually sell for more than the 985 Mark II (the 5 channel) -well from the ones' I've seen anyway.
    Pretty hard to get the 3 channels as well. I see 985 Mark I & Mark II's (and the 1075) all the time going second hand.
    You could buy a couple of Rotel 2 channels (RB-971?), say £100 each. You'll have four channels then, one amp for rears, one for centre (biamped)
  29. mark67
    mark67
    Thanks Guys,
    One last thing. The back of the Tag has Phono O/P Sockets for the surround and centre. Does a 3 or 5 channel amp have phono I/P's?
    Boy do I need to read up on AV.
  30. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    To answer your last question first, yes a typical power amp will have phono/RCA inputs matching the number of channels onboard.
    For example in my system, I have a combination of amplifiers, my rear speakers are driven by a 2ch power amp with 2 phono inputs. I just connect them to the Tag with phono cables to the right sockets and that's it.
    Going off at a little bit of a tangent here, exactly what model is your old Yamaha, is it an E492 or is it the E800?
    Reason I ask is that with the E492 (don't know about the E800), it has 5.1 phono inputs. At a pinch, you could perhaps use the Yamaha to continue driving your front 3 channels until more funds are available. The idea is that you use the Yamaha just to drive the speakers, all the decoding/processing is done by the Tag.
    Of course this wouldn't be as good as a dedicated power amp, but it could be a useful stopgap solution until your funds have recovered.
    It's not ideal because level matching the various speakers could become a bit of a pain, but it is viable.
