TAG AV32R and all its options - help!
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by mattmarsden, May 14, 2003.
  1. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,558
    48
    +98
    I am looking at buying a TAG AV32R.
    The options on it I would like are DTS-ES discrete and 5.1 channel bypass.
    If I buy a basic one without these options how much does it cost to upgrade?
    Does the Dual Shark whatever improve sound quality greatly? Or is it just for the equalisation?
    Is it possible to get an AV32R with balanced outputs?
    Can someone take me through all the upgrading options from a basic unit?
    Thanks very much,
    Matt
  2. mjn
    mjn
    May 24, 2001
    21,878
    Herts, England
    +9,568
    just talk to your local TAG dealer.
  3. nathan_silly
    nathan_silly
    Or phone Tag, freephone no.
    The AV32 won't have XLR connections- too small. Do you need them?
    Have you heard the Tag going in YOUR system? Don't spend close to £1300-£4000 without even be allowed to borrow one for a week, and maybe compare against the Lexicon MC-5.
  4. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,558
    48
    +98
    Thanks guys.
    But does the dual processor version sound any better?
  5. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    Have a look at my third post in this thread for a run down of the different AV32R models and options.
    You'll need a 7.1 model if you want DTS-ES and even then it's an option.
    There are a few DS owners on the forum. I've not heard it yet so ask them.
    No balanced outputs this side of an AV192R.
    I'd recommend contacting Tag for costs. There are some wizards on the web site but they are poor. Options cost different amounts if installed together.
    D.
  6. edward
    edward
    Apr 2, 2003
    870
    32
    Reading
    +29
    Hi Matt,
    The Dual Sharc is quite a bit better - definitely should more lively than the older model. But with som much reserve AD processing capability, this probably shouldn;'t come as a surprise.
    The good bit is the fact that you can run TMREQ, the equalisation software to remove room booms and other imperfections that, frankly, you probably didn't know you had until you hear them removed. I'm only selling mine becuase I've just bought a 192.
    Soundwise, its the same animal, lots of useful features, but I now want teh video processing capability, so...
  7. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    If you're buying new then it's a lot simpler, the only models available as standard are:
    AV32R-EX bp192 - this is 7.1 (EX and ES), has the 5.1 bypass, 192kHz DACs and Pro Logic 2 as standard. HDCD, DTS:NEO and DTS-ES discrete may come as standard, I can't recall.
    AV32R-DP - this is the dual SHARC version, it has all of the above plus THX Ultra 2, DTS-ES Discrete, DTS:NEO6 and HDCD as standard. Also allows for more flexable bass management options, room EQ, Dolby Headphone (optional), Zone 2 support etc...
    AV192R - has all the DP offers, plus allows additional hardware upgrades like balanced outputs, more advanced video switching, FM tuner, video scaler, RS232 control board and others.
    (That's all from memory so I'd call/email Tag to verify)
    All three can take an internal DAB tuner and an RF digital input for Laserdisc. The single processor won't have any more major software updates since the older SHARC processor is no longer supported by the manufacturers.
    If you're buying secondhand then most options are listed in the configuration section of the menus, the only one that isn't is the 192kHz DAC upgrade. If you have the serial number then you can call Tag to find out the history of the unit and what upgrades it may have had. Any processor can be upgraded to a later spec, but the price may vary depending on things like how old the unit is.
    The dual SHARC does sound better than the standard AV32R, not just because of TMREQ, but also due to the better processing allowed by the extra power. My own AV32R is a bit of an oddity since it was upgraded to dual SHARCs and 192kHz DACs, but it remains 5.1 with no bypass.
  8. NicolasB
    NicolasB
    Oct 3, 2002
    6,440
    Emily's Shop
    +888
    The dual-processor Tag sounds remarkably much better than the single-processor version. I was really quite surprised at the difference.
