Tablet project
=adrian=
Joined
Jul 4, 2007
Messages
17,603
Reaction score
7,349
Points
3,656
Location
The Internet
I have this spare Android tablet, generally used only for displaying time. I would like to integrate it with my PC, to be displaying temperature (CPU / GPU), maybe usage graph (if possible) and current time. I would like it to switch on with the PC and turn off when PC goes to sleep. I don't mind completely wiping it and loading a new OS on it, or whatever is needed to get this running. Tablet is old Samsung Galaxy Tab 2. I know we have few knowledgeable people around. How would you go about doing it?
Not sure about the power side of things, but have a look at apps like this
Remote System Monitor - Android Apps on Google Play
Thanks for that, mate. I had no idea such app existed and after the initial blond moment I have it running. And it works! However, graphically the app is very limited, the graphs are not very clear and the little modification available is not really working for me. So back to the drawing board. If I can't find anything else, I'll go back to this one, at least it works.
Not happy with the layout, but it's a start
OK, so I seem to be getting along with the software side of the project, but what I have no idea how to do, is I want the tablet to be sitting inside of the PC case. I will have no access to physical buttons then. How to make it so that the tablet switches itself on, when the PC starts and fires the monitoring screen without me to touch anything.
What a novel idea, a touch device you never touch........
Maybe Tasker or Llama Android apps could help you automate the startup. They can be a little tricky to configure. Could look for when the tablet starts charging when the PC turns on if it's connected to a USB port on the PC, although if the PC is off for a long time there's a risk the tablet could go flat.
Sadly that model can't take power through USB connection, only from mains.
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
