Tablet Galaxy pro 10.1 will not miracast in full screen
Discussion in 'Tablets Forum' started by Keithhampson, Jun 14, 2015.
  1. Keithhampson
    Keithhampson
    Apr 22, 2005
    674
    +6
    Hi can anyone help, when I miracast my screen on my Samsung galaxy pro 10.1 it will not miracast in full screen on my 55inch lg TV, its like 4:3 and has black borders at each side. I can't change the aspect ratio on my TV and I have also tried unchecking screen rotaion on my tablet but nothing works, I get full screen when I miracast from my hudl 2 but not my pro.
    Anyone help with this thank you.
  2. Keithhampson
    Keithhampson
    Apr 22, 2005
    674
    +6
  3. Jamie
    Jamie
    Jun 27, 2007
    5,395
    2
    Harrogate
    +1,405
    The screen resolution is 2560 x 1600 which is a 16:10 Aspect ratio whereas your TV will be 16:9.
    You can get apps that change the screen mode temporarily or there's a command you can type to change it in a command terminal. I'll post back in a few once I've found my post on another forum on just this subject. Both methods will make the display on the tablet look quite weird and poor quality so I would only use them if playing videos on your TV or if using a mouse or other means for control
  4. Jamie
    Jamie
    Jun 27, 2007
    5,395
    2
    Harrogate
    +1,405
    OK I'm not sure if this needs root or not.
    The app was called second screen, the app definitely does need root.
    https://play.google.com/store/apps/details?id=com.farmerbb.secondscreen.free
    The manual way is a command run at a command line (download a terminal emulator from the play store)
    Type:
    wm size 1280x1080
    Or
    wm size 1024x720
    And to change back type
    wm size reset
    Or a reboot will reverse the changes if you have any problems.
    I've got no idea if the command line way requires root or not, if you're not rooted it's worth a try.
