I wasn't sure which forum to place this in - hopefully this one is the most sensible!
Our 32" TV in the bedroom is on top of a dresser, basically in the corner of the room and angled.
I'd like to add a Sonos Beam to the set-up to extend our multi-room music upstairs and help with the TV audio, but with this arrangement there's nowhere to put the soundbar - no space on the dresser without it overhanging badly.
I'm imagining a tabletop TV stand which can pivot, so the base will be square on to the dresser, but the TV itself can be at an angle. But for the Beam, I'd need it to have a built in shelf low down for the Beam to sit on - but I'm struggling to find such a thing.
Have I made up a product which doesn't exist? Can anyone recommend such a thing - or an alternative solution?
We can't wall mount, as it's in a bay window. And I don't think that the generic soundbar brackets you can get will work with a Beam, as it only has mounting holes on the bottom, not the back.
Thanks for any advice.
