table mount for LCD needed!
richard plumb
OK, so I'm selling my philips 30pf9975 after buying my new toshiba. Reckon £500 is a reasonable price (even though it cost me £2k!)
Has a wall mount, but I've lost the 'feet' it used as a table mount. Ring up the parts supplier. £130!
Thats disproportionately expensive so not really an option.
Can anyone help with a cheaper foot mount? It has 4 screw holes on the back in a square, about 300mm between holes. It used to have two vertical poles on the back, about 1/3 in from each edge.
cheers!
wullsy
did you actually sell this lcd, Richard ? I noticed it on the for sale forum...I asked a few questions on the thread...and then it disappeared !
cheers,
Trending threads
