tab screen
Discussion in 'Projectors, Screens & Video Processors' started by dis, Sep 27, 2003.
  1. dis
    dis
    May 20, 2002
    611
    43
    england
    +202
    Just a quick one
    Thinking of getting the nec ht1000 would a 1.5 gain screen be allright
    Nix nex are selling 6foot 16.9 tab tension screens at a very good price.
    Thanks ………..dis
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,150
    UK.
    +2,670
    I'm using a 1.2 screen with mine, and running in eco mode with the iris shut. Screen size is 84ins wide by 47.25ins high.
    I would think the screen would be OK at that size provided it doesn't hotspot. At that size though, even a unity gain screen would work well. You may find the blacks a bit brighter than necessary though. You can always add a filter later I guess if it's too bright.
    Any way for you to get a sample of the material as well as some others so you can try it out before you buy?
    Gary.
  3. Kramer
    Kramer
    I'd say a 1.2 would be more suitable.
  4. dis
    dis
    May 20, 2002
    611
    43
    england
    +202
    hi
    thanks gary&kramer will take note
    cheers.........dis
