Quantcast
T500mA fuse need to replace
highlanders
Hi all
My RC9200 dock is dead and I had a look over at remote central and found out that in most cases when this happens it's the fuse inside the dock, had a look and checked and it and it needs to be replaced. Just phoned Maplins and all their fuses go in holders this one in the dock has to be soldered in place, has anyone had to replace theirs and if so where did you get it from?
fraggle
Just go to Maplin and buy their fuze (box of 10 is a lot cheaper than singles) and a suitable fuze holder and solder fuze holder across blown fuze (use couple of extension wires - don't solder fuze holder directly to PCB otherwise when you change it in future you risk ripping tracks off the PCB!)
vizslaraner
Some nice, er hum, gentleman sent some fuses, but alas the dock has ceased to be; shaken off it's mortal coil and gone to meet it's maker. It's an ex dock.
highlanders
But at this very moment it getting the kiss of life, failing that dead but not forgotten, l'll say a prayer on your behalf.
