T2 - region 1
Discussion in 'Movie Forum' started by hitz, Jan 29, 2002.
  1. hitz
    hitz
    Dec 18, 2001
    68
    I have just bought the dvd T2 region 1.
    i was looking for the THX test menu - where it enables you to setup your speaker etc correctly - but it doesnt appear to be on either disc. Can someone confirm where it should be.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,523
    Somewhere in South Yorkshire
    +5,996
    Go into the setup part of the menu on the main disc (I think its called Sensory something....) and look for the THX logo on the side of the Terminator's head.
  3. hitz
    hitz
    Dec 18, 2001
    68
    Cheers - I'll try that tonite and let you know how i got on.
    By the way - i played a bit of the DTS version - and it sounds the dogs b*llocks
  4. damtom1
    damtom1
    LISTEN TO THE PART WHERE SARAH CONNOR DRIFTS INTO A DREAM,AND WATCHES HERSELF IN THE CHILDS PLAYGROUND AS THE BOMB DROPS.(ABOUT 1HR 28MINS).LISTEN TO IT IN 5.1,THEN IN dts.IT SOLVED THE ARGUMENT BETWEEN THE TWO FOR ME.
  5. hitz
    hitz
    Dec 18, 2001
    68
    I also watched Gladiator (R1) in DTS - and sounded bloody excellent.
    Has anyone got any other reviews on DVDs that really push your setup and make it work hard.
    and before someone mentions matrix - i have already got this.
  6. damtom1
    damtom1
    As a rule i always find any space or underwater sequences really create an atmospere,great bass sounds to test the sub.Also the cartoons (Toy Story,Bugs life,Tarzan)all have a great detailed sound.
    The Abyss
    Saving Private Ryan
    Apollo 13
    Jaws
    T2
    Unbreakable
    any of these in dts,are a just a few good examples!
  7. mjn
    mjn
    May 24, 2001
    22,720
    Herts, England
    +10,860
    sod the matrix......
    for some low end rumble.....End of Days, near the beginning with engineers working in the street....
    music quality...the end of Gladiator, where Russell Crowe dies
    Aliens....where the remote ship crashes..what an explosion
    motorbike chase in MI2.....superb use of surrounds..
  8. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    Thanks for that.
    I've always struggled to hear any difference between DTS & DD but Im pretty sure I can notice on this.
    DD Bass felt a little 'boomy' where as DTS base was more intense and direct.
    For information I did this test on a Denon 3802, Tosh sd210 & Kef kht2001 5.1 speaker set.
    PS...
    In future you might want to type in lower case.
    Caps is regarded as SHOUTING and is frowned upon where not neccessary on most Forums/websites.
  9. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Some good effects DVDs:
    The Long Kiss Goodnight (shootouts)
    Bad Boys (score, shootouts)
    Heat (bank robbery scene)
    The 5th Element (the whole movie!)
    Das Boot (>200m)
    Roy Orbison Black and White Night (music)
    Else the ones which have been mentioned already: The Abyss, T2, The Matrix ...
  10. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    U-571 (r1, DTS soundtrack) - one of the best dts soundtracks i've heard - standout moment is chapter 15 (i think) - the depth charge scene. i think it really scared the neighbours!
    Gary
  11. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,724
    EU
    +795
    On the subject of T2..........Is there any difference between the R1 and R2 versions, especially in sound?
    THe price is pretty much the same, so which one is the best to buy?
    Thanks for any replies.
    RDB :)
  12. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    Buy the region 1, its a better disc, but only in terms of the 3 versions of the film on the same disc branching option. I haven't heard the R2 version, so not qualified to say, sorry.
    Gary
  13. skimber
    skimber
    Dec 1, 2001
    205
    19
    The R2 has nicer packaging... a proper hinged metal tin... whereas the R1 has a sheet of bent metal. But it's the disc that counts :)
  14. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    I prefer the reg 1 over the reg 2 the metal is thicker and it looks better ,the reg 2 looks like a tobbaco tin.only my opinion.
    cheers Dave.
  15. mjn
    mjn
    May 24, 2001
    22,720
    Herts, England
    +10,860
    the r2 has better packaging i reckon....proper hinged tin..rather than bit of bent metal.....
  16. Black 5
    Black 5
    Jul 19, 2000
    367
    19
    Isle of Man
    +3
    More great sounding system stretching discs - Titan AE, Final Fantasy and the Mummy Returns
