T2 Extreme DVD help
Discussion in 'Desktop & Laptop Computers Forum' started by r-06264, Apr 21, 2005.
  1. r-06264
    r-06264
    Oct 4, 2004
    108
    Cape Town
    +3
    Hi all
    Just got this disc today and without having to change my proxy settings it told me it downloaded the licence file successfully :smashin: I just want to know why InterActual Player needs to be installed. I thought Windows Mediaplayer is needed? I can't get it to work with WMP as it says there's a problem with my video card (I think I need a region-free software plugin). It works with InterActual Player btw, I'm just a bit confused.
    Hope someone could shed some light on this subject.
  2. r-06264
    r-06264
    Oct 4, 2004
    108
    Cape Town
    +3
    Seems I'm a fool. I was playing the 1st disc. The 2nd disc contains the HD image!! It's now coming up with the licence error. Earlier it downloaded it. Go figure! Now I'm must find a US proxy server :(
  3. r-06264
    r-06264
    Oct 4, 2004
    108
    Cape Town
    +3
    None of the proxies are working :( Does anybody know how to get around this :lease:
  4. Kramer
    Kramer
    You'll have to find a working proxy then ;)
    IIRC, education servers worked well. It'll have to be an open server too, not anonymous etc.
    :smoke:
  5. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    There is a thread about this in the DVD forum which has the details of a working proxy, or at least it did work a few weeks ago.
    Good luck, as it's well worth watching.
  6. Erling
    Erling
    Dec 4, 2002
    81
    Denmark
    Take a look here:
    http://www.theatertek.com/forums/showthread.php?t=7410
    I've described in this thread how I got it working on my PC. There's some Theatertek specific info, but you should still be able to get the needed knowledge to run it with other software.
    Cheers,
    Erling
  7. r-06264
    r-06264
    Oct 4, 2004
    108
    Cape Town
    +3
    Thanks guys!! :) I'll have a play tonight again. Will let you all know.
  8. DaveP
    DaveP
    ISTR that you only need to copy the WMV file from the DVD to the hard disk and it plays fine!
    Worth a try if yoiu are still having trouble.
    Dave
  9. r-06264
    r-06264
    Oct 4, 2004
    108
    Cape Town
    +3
    Thanks for the help folks. I got it working by the looking at the link Erling posted (Thanks!). The biggest obstacle that I had to overcome was trying to find a transparent proxy that would actually work. All sorted now. Quite happy with the overall picture quality and sound :)
  10. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    I have this on order from Axel Music so it would be great if you could share the proxy info.
    Ray
  11. r-06264
    r-06264
    Oct 4, 2004
    108
    Cape Town
    +3
    PM me, will be glad to help. I'm sure if such info could be dislosed here then someone would've given me a working proxy.
  12. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    They have been put on earlier threads but perhaps that's why they disappear so quickly!
    Will PM you when T2 arrives.
    Ray
  13. MikeFish
    MikeFish
    I'm waiting for my copy too (Play are currently out of stock).
    some people have said they've had no problems with it. Hopefully i won't either but if this isn't the case I'd appreciate you help too! :lesson:
  14. r-06264
    r-06264
    Oct 4, 2004
    108
    Cape Town
    +3
    Help is always available just shout when you need it. Have recently helped someone else as well so can confirm that the proxy is still working.
  15. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    :lease: What am I doing wrong?
    I have spent hours trying different proxy servers with no luck. I either get a message that says something like - "It appears you are using an anonymous proxy server so can't issue license at this time" or "Please insert your DVD to continue if your DVD doesn't start automatically, please start it by running X:\install.exe ..........etc " :eek: But the DVD is in the drive and running install.exe doesn't do anything!
    Can I just check, is it a transparent proxy I need coz surely a transparent proxy passes on your IP address so won't that indicate a UK location?
    Any proxy hunting tips or a kindly PM would be really appreciated.
    Many thanks
  16. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    Here's the one I used
    216.126.204.21 port 8888
    I hope it still works.
  17. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    thanks Stripe & Orangeteam.
    Still having the same problems. I am beginning to think it it's not the server settings but some other kind of problem on my PC. God knows what though. :rolleyes:
