T2 3rd version on R1
Discussion in 'Movie Forum' started by Mikeonfreeserve, Jan 16, 2001.
  1. Mikeonfreeserve
    Mikeonfreeserve
    On the Electronic Reality site it mentions a 3rd and hidden version of the movie on the R1 disc.Can any helpful soul familiar with the Cyberdine layout help me find it?
  2. bradavon
    bradavon
  3. PoochJD
    PoochJD
    Aug 28, 2000
    10,992
    Norwich
    +1,861
    Mike,
    Can't believe that you haven't heard of how to access the extended Director's Cut on the T2: Ultimate Editon disc!!! ;-)
    However, here's how to access it:
    1) Go to the Film choice screen.
    2) Quickly press the following numbers on the keypad of your remote control, in this order: 8-2-2-9-7
    3) As you type each numeral in, the words, "The Future Is Not Set" (or something similar) will light up. Then once completed, you will be given the choice to play the longer version of the movie. However, be warned: depending on your player, you may not be able to play the movie at all!
    Pooch
  4. Mikeonfreeserve
    Mikeonfreeserve
    Thanks Pooch.Pause and 3 cracked it on my trusty MiCO.Suppose you've found the rhino on Gladiator too?
  5. Mikeonfreeserve
    Mikeonfreeserve
    And thanks for the link Brad.
  6. PoochJD
    PoochJD
    Aug 28, 2000
    10,992
    Norwich
    +1,861
    Mike,
    What Rhino on "Gladiator"?
    Please tell me all....! Is this on the movie disc, or the extras disc, and is it on the Region 1 or 2 version?
    Pooch
  7. Mikeonfreeserve
    Mikeonfreeserve
    HiPooch,
    Can't believe you haven't found the cgi rhino on Gladiator?!
    Touché?!
    Mike.
  8. bradavon
    bradavon
