stegalv
Been waiting 5 wks for delivery of amp and speaker to finish my sub,so while waiting i have been searching forums for snippets of info to help with my first build.
After seeing ads and threads about using t-nuts to fix the speaker to the box i have purchased some locally, bloody typically just read a thread with around 8or 9 replys saying don't use
t-nuts as they are rubbish, that they do'nt hold very well and if you try to remove the bolt it pushes the t-nut out at the back so it will just spin.
Nearly all recmmended ordinary rough thread screws.
Any comments from experienced builders
