System panel header ALiveNF6G-VSTA mobo
Discussion in 'Computer Components' started by steamman, Jan 16, 2008.
  1. steamman
    steamman
    Jan 16, 2008
    4
    Hi I am trying to install the front panel wiring to the system panel header. I have completed the install but cannot power up the pc.The fan on PSU will not spin only the power light is on front panel of tower.I tried a new PSU thinking it may be that,same result. I followed the manual and it says to fit the panel wiring to system header, That is ok its whether they are to be vertically fitted or horrizontal. I understand that the delta icon on the connectors means the positive and that the pos is indicated with a '1' at the mobo, and gnd is earth, BUT whichaway round do they fit. This may be the prob with non fire up.
    The leads are PLED+,PLED-,PWRBTN(followed with hash sign),HDLED+,HDLED-,RESET(hash).
    There are GND,shown on manual, but as to where they fit :lease::rolleyes:
  2. steamman
    steamman
    Jan 16, 2008
    4
    From steamman. to forum Sorry for post duplicate, I had logon appear twice during the thread composing:oops::oops:
