Could anyone advise the best way to connect the following equipment I have a 42" Panasonic plasma TV TH-42pa20 with the following connections 3 scarts (2rgb), component video, s_video input, composite video input, stereo audio input, stereo audio output. I will be using SKY+ which has 1 scart vcr,one tv, S-video, optical audio out, rs232, audio out L/R, areial in, rf out 1. rf out 2 And awaiting my DENON DHTSD to arive with the following connections. SURROUND RECEIVER Audio terminals input:4 sets of analog,2sets of optical digitall output:2sets analog,1set of optical digital,pre outputs for subwoofer and surround back l/r
SKY+ to RGB scart AV1 IIRC and optical to denon do you ahve a DVD ??? IF so connect via component to AV4 if you have no DVD i suggset you buy a panny DMR-E55 DVD reocrder and connect to AV4 via component and scart Odd but works well
yes within the system see link: http://www.avland.co.uk/denon/dht550sd/dht-550sd.htm what do you mean by component to scart av4??
ah PA20 i thought it was PA30...... use component for DVD and Scart for SKY+ but try S-video from sky+ you may prefer it as PA20 doesnt handle RGB very well
