System configurations!
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by 602sqn_Crater, Jul 7, 2002.
  1. 602sqn_Crater
    602sqn_Crater
    Hi all,
    A bit of help needed!
    My system:
    XP2000+
    256mb DDr Ram
    GEforce3 Ti200
    Audigy Soundcard c/w firewire port
    Memorex CD Writer
    60gig 7200rpm HD ATA100
    15gig 5400rpm HD ATA100
    Windows XP Pro
    Adobe Premiere
    I am going to do a clean install. What would be the best configuration for DV editing? (i.e. Should I use the 15gig for XP and software and leave the 60gig purely for DV? SHould I set the swap file to a different drive from the OS? Should I make the 606gig the secondary master?)
    A hell of a lot of questions I know! Can you help?
    All the best,
    Crater
