System change due to new plasma?
Discussion in 'Home Cinema Buying & Building' started by wokster, Oct 16, 2004.
  1. wokster
    wokster
    Nov 9, 2003
    309
    Ecosse
    +6
    I am a complete novice to this so please bear with me.
    I have a DAV-S800 and like the fact that it is an all in one syatem so I would like to keep it like that. The problem is that I am about to buy a Panasonic 42 Viera and have been told to go for a DVD player with progressive scan.
    Does anyone know of a good all in one syestem that has progressive scan on it or could I buy just another DVD player but still use the sound from the DAV-S800.
    Also if I was to sell my DAV-S800 system what would be a reasonable price to ask for it?
    Any help would be greatly appreciated.
    :thumbsup:
  2. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    Denon DHT 500 SD. Latest digital sound processors, 6.1/7.1 expandable, top rated in all the correct magazines (95%), PAL progressive scan, about £400 over the internet. See the threads discussing it.
    Hope this helps
  3. Ged
    Ged
    Apr 29, 2002
    925
    +17
    From my limited experience it appears that the plasma may do the prog scan de interlacing better, making it easier to find a Component output only system.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    All plasma will deinterlace and scale any video source before displaying it.... £400 on a DVD player will give hugely better PQ than a £400 all in one. so if you are happy with DAV400 and it has an optical input or Coaxial input then i suggest you buy a DVD recorder something like a Panny DMR-E85 and keep sony if you are happy with the sound quality from it. Or go for an all in one like the panny SC-HT37R
