System advice - Monitor Audio Radius
Discussion in 'Home Cinema Speakers' started by alfieginger, Oct 28, 2005.
  1. alfieginger
    alfieginger
    Hi there,
    I'm running Monitor Audio Radius 270 floor standers front, and 3 R180's for centre and rear surrounds. My sub is a Rel quake and my amp is a pioneer AX3.
    I find the sound a little harsh a high levels and wonder if the Pioneer/monitor audio combination is not a match made in heaven. I also feel that the rel is a little weak in my 6m x 4m room.
    Can anyone suggest a Mid range Av amp that will complement rather than clash with Monitor Audio's, I don't want to change the speakers as I feel thay are superb for the money and have a reasonable WAF level!!
    Finally, what sub's work well with the MA's.
    Many thanks, any help gratefully accepted!
  2. spine
    spine
    I use a Marantz SR4500 receiver with four MA R90s and R180 center and they sound very good.
  3. alfieginger
    alfieginger
    Thanks for that I'll have a look at the Marantz range then.
  4. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    check out Denon too, they work well with MA speakers.......i've demoed with Radius speakers, but i personally own MA Silver S series speakers.....
