System Advice For Newbie
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Jkw777, Jun 6, 2005.
  1. Jkw777
    Jkw777
    Good evening,
    I know you probably get a lot of these threads, but each case can be different. :)
    I'm currently after a Micro system, as my current one is sounding a bit weedy and old. My budget really isn't important but I would say a max of about £300.
    I've looked at the Denon DM-31, but I'm not so sure. I want a system that delivers a nice amount of healthy bass, and awesome sound quality.
    What can you guys recommend? I don't want nothing TOO fancy, just something that will be a nice all rounder and to sit in my bedroom/office.
    I look forward to any advice anyone has! Be sure to ask me any questions, if I haven't given enough information!
    Best Regards,
    Justin :smashin:
  2. CharlesElliott
    CharlesElliott
    Mar 18, 2002
    55
    If it has to be a micro, then the DM31 is about as good as you're going to get - although it is now quite a lot under £300 as it has been replaced by the DM33 and 35 (neither of which I have listened to yet). The latter has a DAB tuner but blows your budget.
    The TEAC CRH 250 is within budget and has a DAB tuner, but isn't quite up there with the DM31.
    It's a bit above budget and doesn't come with speakers, but something like the TEAC Reference 300 MkII (e.g. see http://www.empiredirect.co.uk/content/products/details/html/TEA-REF300-MKII-DAB.htm) would be in another class altogether. You might be able to find a good deal on it.
  3. Jkw777
    Jkw777
    :) Thanks for your help there.
    It seems that no one has the DM-31 in stock anymore!! :mad:
    Back to the drawing board. :rolleyes:
    Any ideas people? :lease:
    Regards,
    Justin :thumbsup:
  4. CharlesElliott
    CharlesElliott
    Mar 18, 2002
    55
    Superfi and Richer Sounds both claim to have stock.
    If not, then either go for the DM-33 or the TEAC CR-H250 (I've just bought one of the latter and it compares well with the DM-31; plus I wanted a DAB tuner)
  5. Daveace1
    Daveace1
    Apr 7, 2005
    207
    Coventry (West Midlands)
    +5
