Synch probs Camcorder via PC to DVD
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by TomStuart, Apr 7, 2003.
  1. TomStuart
    TomStuart
    I have been editing footage from my Canon mv 550i vis Pinnacle Studio Clip then back to the Canon and finally recording to DVD via Philips 890.
    The final version has the speech and video noticeably out of synch.
    WHere should I begin to look for the problem?
  2. Brian110507
    Brian110507
    You need to break the problem down a bit, is it in sync while you are still in Pinnacle, and is the footage recorded back to your camera OK. Would it not be better to record the DVD straight from your computer without going back to your camera first, that way you would at least remove one stage which could give rise to errors.
