syncblaster problem
Discussion in 'Plasma TVs Forum' started by ariharry, Aug 31, 2003.
  1. ariharry
    ariharry
    Mar 19, 2001
    105
    +24
    I just purchased a Philips dvdr 880 recorder that is connected to a 503MXE via a Syncblaster cable (scart->15 pin din).
    Most films work fine, but on a few films the image jitters.
    I saw a similar posting that stated that early syncblaster cables could not handle certain forms of macrovision, but how wide spread is the problem?
    I emailed Keene who chose to ignore my email, therefore before I battle with them over the phone, is there a simple fix?.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No simple fix, simply that synchblaster is not always up to the job. You've tried with and without the power supply? I've used exaxtly that setup but with a JS rgb-vga converter, and had no trouble.
  3. ariharry
    ariharry
    Mar 19, 2001
    105
    +24
    Tried with and without power supply, no difference. :(
    If there is no fix, then I may just dump it and buy a JS box...
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's what I'd recommend on experience. BTW does the plasma have time in these picture glitches to pop up a message, like 'Out of range', or similar?
  5. ariharry
    ariharry
    Mar 19, 2001
    105
    +24
    Yep. When there is a picture fade-out or no picture displayed, I get a complete loss of sync (i.e I get a message)...
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Then the synchblaster is not coping with the vagaries of scart from the dvdr. Better and more expensive converters are better at this. I have installed a DVDR880 with a JS vga converter without such troubles. It could be the rgb signal from the scart is not that good, I've heard of this trouble with synchblaster before, though I used to have one at home that was hassle free.
