Syncblaster Cable
Discussion in 'Plasma TVs Forum' started by bluevortex, Mar 2, 2005.
  1. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    I have the syncblaster Scart to VGA convertor from av sales, for my sky box to PW7. I have read alot of threads about the Js tech RGB to VGA as being the best.
    Does anyone know if this would be better than the convertor im using at the moment? Would there be much noticable improvement over syncblaster?
    blue :rolleyes:
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    blue, I upgraded from sync blaster to JS and pq is certainly better....whether it is £120 plus cost of cables better is relative I guess..but its definitely better. Oh and its definitely the first sign of upgraditus! :)
  3. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    Is it better than the QED Q-SYNC convertor?
  4. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    can't comment on that as although I did try the q-sync that was on the tiny and notthe pw7 and it made only a little difference but I'm sure that is more down to tiny and not QED....i've now returned the q-sync so cannot run a comparison with JS.
  5. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    Anyone else?
  6. nobbydog
    nobbydog
    Jun 19, 2003
    262
    Comfy basket in the utility room
    When I bought my PW6 I tested the syncblaster and the QED Q-Sync and neither impressed me. I decided to buy the JS box blind and it was well worth the money, if anything you need to tweak the colours down a little (which takes some fiddling as the colour adjustment is actually lost from the menu options!). For what its worth I would definitely recommend it although others here may have different experiences.
  7. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    I went from S-video and bought the JS Tech RGB2VGA because i thought it would give some major improvement with my sat-receiver.
    I was wrong, the JS Tech does a fine job, but it is not some magic box that can make your picture brilliant, if you already have the S-video option, then upgrading to the JS Tech RGB2VGA box won't give any major improvement.
    I do think the JS Tech box is a bit hyped in this forum by some people, none mentioned.
    In my case the picture got pretty much softer, however the colours are a bit better and the signal is much more stable, the JS Tech unit does a very good job in delivering a stable signal, i can't deny that.
    Is it worth £120 if you upgrade from S-video? no
    Is it worth £120 if you upgrade from composite? yes if don't mind spending the money.
    After all, i would have saved the money and bought a used Iscan HD scaler instead from USA for £400.
  8. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    What about upgrading from scart?
  9. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    so bearing in mind ive got the syncblaster Scart to VGA (£77)
    is it worth the £120 for the JS tech box, bearing in mind im buying blind as nobody i know has a plasma round here and i doubt i could arrange to see one before sale.
    I guess i could sell the syncblaster, but is the PQ on the JS going to be noticably improved?
    mep, upgraditus, i'll say . . currently looking into getting my second screen for bedroom!!
    why cant i have cheaper intrests
    blue :suicide:
  10. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    bottom line, you wont be happy till you get one coz it will always be nagging at you....I was happy with the upgrade but with cables it has cost over £200 and I don't regret having spent the dosh....
  11. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    If it's nagging you, buy one! otherwise you will always be wondering....
  12. JulianL
    JulianL
    I'm planning a PWD7 with JS box and I'm a bit worried about the colours being too high for my taste. I thought they couldn't be adjusted at all on the Panny via the VGA input. How do you get to the colour adjustment for the VGA input?
    - Julian
  13. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    you can still mess around with contrast, brightness and advanced settings
  14. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    You don't need to adjust the colours as they are set at the correct level anyway, that's why it is RGB.
  15. alanfcross
    alanfcross
    Has anyone compared the Maplin "SCART Sync Separator" ?
    They say:
    Input: RGB & Composite sync from DVD or Digital Satellite or Cable
    Output: RGB plus separate Horizontal & Vertical syncs For connection of AV equipment to Plasma, LCD TVs and Video projectors with 15-pin inputs
    At £49.95 it's the cheapest, but is it the nastiest too?
  16. freeman
    freeman
    Dec 27, 2004
    240
    +11
    I've got one & am very happy with it :thumbsup:
  17. Rambles
    Rambles
    Jul 14, 2004
    10,442
    167
    UK
    +2,151
    Interesting - Maplin have a very good returns policy....
  18. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    Are these convertors better than using a scart board?
  19. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    scart boards have a reputation for soft picture....the converters give a much sharper image
  20. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    Worth £120 extra?
  21. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    I always say that is relative to how much £120 is worth to you...and dont forget you also need qood quality scart and vga leads so realistically you should be looking at £200.
  22. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    That's silly. You could say the same thing about any style of input. In fact YUV is more tolerant than RGB and on the Panny YUV (component) has colour adjustment and RGB doesn't. Any input is going to have processing errors that you will want to adjust, and there are individual tastes to consider.
  23. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    Im tempted by the JS. was happy with syncblaster to begin with but in days gone by im starting to notice sky going from good picture, to bad. Some channels are at times quite blurry - sharpness settings on PW7 seem to do very little to stop this. Perhaps the JS will give better results. . .
    what do you think?
    blue :rolleyes:
  24. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    before I bought mine I pm'd Liam who had compared teh 2 side by side....he said>>.
    "the quality difference between JS and Keene is down to the processing and cable used. Both routes have the various advantages of a decent RGB signal so both are going to come off sharp and solid. The JS adds better colour definition and less noise through using a better chipset to carry-out the sync-splicing. The further advantage comes from being able to use high quality cable to and from the converter. We're not talking leaps and bounds but the JS is better, and with it passing totally unadulterated picture information it will immediately look quite bright compared to the Keene"
  25. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    Where's the cheapest place to get one from?
  26. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    you can buy them direct from js, av sales charge a few quid more but include postage
  27. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    The JS Tech converter gives a soft picture as well if you don't set the sharpness control at max 15
  28. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    it doesn't on my pw7 mate, i have sharpness at 6 and its as sharp as a very sharp thing
  29. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    I can't promise what the results will be as it seems to be case by case.
    I bought the JS Tech RGB2VGA as i thought it would make a major improvement to my s-video connection, however i am pretty disappointed by the results as i have already said.
    The picture is quite blurry or soft, if i set the sharpness controll to 15 i will get an acceptable picture but it is too blurry for me.
    Why is it blurry? no one knows the answer to that.
  30. AFC
    AFC
    Sep 9, 2004
    76
    I've just upgraded from using S-Video which I was happy with but like someone said here, I wasn't happy until I got myself a JS Box (RGB -> YUV)
    I'm still tweaking my settings on my screen but the first thing I noticed was how rich the colours are, perhaps a bit too rich. The picture does however look sharper and more stable, no banding from Sky+ (or am I trying to justify the purchase to myself ;) )
