Sync On Green Via DVI Question
Discussion in 'Projectors, Screens & Video Processors' started by dean randle, Mar 18, 2003.
  1. dean randle
    dean randle
    Jan 9, 2003
    156
    UK (Bromley)
    +6
    Could someone please explain what this means, as I've seen a Sharp Projector that claims that the DVI terminal is NOT compatible with sync. on green function.
    Thanks in advance
    Dean.
  2. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    Some flavours of DVI connector can carry both analogue VGA and Digital data. So any reference to synch on green must apply to the analogue signal. You can spot a VGA/Digital DVI socket as it has some extra pins.
    Normal DVI
    DVI+VGA
    :D
    Most PC cards have the DVI+VGA type so you can plug in one of those DVI->VGA adaptors to take advantage of dual VGA displays.
    -- Jon
